Hi guys, I wonder if you could shed any light on the following problem:
Sometimes (most of the time), the roof simply fails to operate. This can be whether it is in the up or down position. Nothing happens when i press the button, no noises clicks or anything else. Sometimes driving around for about 10 minutes and then trying again seems to fix it. This seems to be happening more and more! any ideas?
There are some better sources for help in this site, but here are some comments that could help. These apply to a 98 and I believe are appropriate for other years.
As you probably know the top will not operate until, the ignition is on, the parking brake is engaged and the latch is open. There are some other rules like the speedometer signal can’t be greater than 5 km/h – not clear how this would happen if the parking brake is engaged.
The most common problems appear to be a defective microswitch in the parking brake, a defective microswitch in the latch and a problem with the relay. These are covered in earlier issues in this site.
As a quick check you could try the following. If the windows drop when the latch is opened, the latch switch is probably ok. If the parking brake light goes on when you engage the brake, the parking brake switch is probably ok. This would leave the problem with the relay. Earlier post indicate if you remove the relay and then give it to a dog, an active child or roll it on the floor and plug it back in it works – must be something loose in the relay.
Good luck.
In order to make the roof move the car needs to think the hand brake is on. That is done via an electrical switch on the brake lever when it is pulled up.
The switch was crappy on the early cars, and a new style switch came out a few years ago.
When the top does not work. Start the car and pull up on the brake lever. If you do not see the hand brake warning light in the instrument cluster go on then that is the problem.
Thanks Guys,
I have tried the handbrake and the light seems to work ok. Also it seems like the switch is ok because the windows go down when i press it. So that leaves the relay - where is this and how do i remove it? apologies for my ignorance, but i only gor the car last week!
many thanks
Nick
Edited by npfx
