03 TT tip -- systems 2 says Air Mass Meter Fault. Car is OK on start up and warming up. Leave for 20 minutes and come back, ABS ABD does not work. It then hunts at idle and run rough. The Air Mass Metre has been replaced 3 times.
Any help much appreciated
Without looking at the MAF (with a PST2 or PIWIS tester) it is impossible to tell if it is functioning correctly.
Either you have had bad MAF's, you have a wiring problem or your brake light switch is intermittent. Another possibility is an intake leak - do you have the stock intake system?
Car completely stock. Recent flash upgrade - problem was present before flash.
Porsche flash or 3rd party flash?
3rd party. The same problem existed prior to flash. Sort of hoped flash might solve the problem!
also check the high pressure air hoses onto and from the turbo! i had one that seemed ok but one hose clamp had broken and was giving a leak that led to same warning lights!
