just recently the radio on my '98 2.5L began crackling, but only when on AM mode. It gets worse as my RPMs increase. Is this in fact the ground losening? :huh:
Peace,
Parker
What you are hearing is the spark plugs firing. That used to be a shade-tree mechanics tuning tool.
If it has suddenly become much louder you could have your mechanic look for a loose ground in the stereo system or check the engine wiring harness for wear. If the lines from the the amp to the head unit are not properly shielded it will be loud. The antenna doesn't pick it up as well so although you can still hear it it's quieter. It's easiest to hear when you are between am stations. If you hear it all the time then it's most likely a loose ground between the head unit and amp.
