Hi guys need your help again i drive 996 c2 tip. This morning when i started the car the key sticks to a position where the air condition and accesories do not work so i turnd the key back a liittle bit and it worked. does my ignition switch needs replacing? any help would be appreciated thnx!:)
yes it sounds like the actual ignition switch needs replacing as this is the component that has the 'gates' and springs of the various key positions in it. some people think its the housing but without switch on the housing you can simply turn the key without any resistance. so change the switch first!
Thnx for your reply if i replace the switch should i go to the dealer? coz in my country we only have one dealer which i have to ship my car. does the switch come with a new key or still use the old one?:)
porsche dealer wont supply switch. they will only supply it with whole lock housing. you need to get it from audi or vw dealer as its same. if you take yours off you will see the part number. you dont get keys or anything. just switch! its about £10 here in uk.
get it from a VW dealer., its a 20 dollars part
