Hi All
Anyone know how to adjust the front wiper arms???
The passenger side (UK Right Hand Drive so on the left) misses the bottom of the windscreen right in the middle beneath the arm wiper pivot
The Drivers Side doesn't wipe fully for the full arc at the same point.
Bought new genuine Porsche blades thinking that the old ones were at fault, but the new one are just the same. :(
Cheers
Lee
Over here I was told that the dealer had a hand tool to realign the arm angle, the arm needs to be twisted slightly, only a few degrees.
Hi All
Cheers
Lee
Hi Mudman
Thanks for the quick reply, the blades are perfectly silent, so don't think it needs the tweak.
It more like the arm needs to apply more pressure???
Any ideas onyone?
Had mine adjusted when I replaced the windshielf. the drivers still sits a little high for my liking. They are very difficult to remove and there's a washer in there that has to be replaced every time the wiper arm is removed and reinstalled. So, don't removed it unless you have that washer. The dealer should have them in-stock.
