This is a weird behavior I saw today. I have a '04 C4S with the Stock CDR-23 (no Bose).
I stopped at a corner store to grab a drink. When I got out of the car I know the radio was off. I know this because I'm currently using a FM modulator to listen to my iPhone. So when I disconnect, I hear static until the radio shuts off.
When I got back into the car and put my key in, the radio turned on. This was before I turned the ignition...
Anyone else ever see this behavior? I'm chalking it up as some kind of bug (or maybe I did ever so slightly turn the ignition). Just kind of weird. Not use to something turning on unexpectantly... just turning off ;)
Sounds like the classic problem with the ignition switch going bad!! Have you noticed any irregularities with the dash lights just before ignition ??
Do a searc hfor ignition switch and you will a DYI as well as many other posts on the subject.
My $.02 Demosan
The opposite happens to mine randomly but it happens when the ignition is on. I don’t think it’s my switch since I replaced it a couple of years ago. Let us know what you find out. GL
This is normal AFAIK.
Edited by wross996TT
So normal that it has only ever happened once?
When you get in your p-car and just insert your key, your radio turns on?
I think so... my Mercedes does the same thing too.
Yes every time...as long as the radio was on when I shut it down.
