Hi all,
I was trying to remove my alternator so I can do the oil filler tube replacement. The DIY here called it a "simple" job, that is NOT true. On the c4 I have, after removing the two alternator bolts- trying to move the alternator clockwise is not possible since there is a bunch of stuff right above the alternator. Does anyone have a DIY for this job? I think I have gotten myself into a bad spot w/this...
thank you in advance
meek
