Is the lower cushion element calculated to an exact resistance depending on the "size" of the element or can I trim it.
If not I will have some of the element on each bottom cushion wrapped under the cushion directly on the seat. Not sure if that's OK.
I do know I have to split the element into two already and jumper between the two elements since the GT3 seats have 2 separate cushions on the bottom, I just want to trim a little more....
Corey
  • 4 weeks later...
Corey
Just incase anyone was wondering... A chunk of the cushion has no wires in it so it can be trimmed. I just had to hold it up to a bright light to see where the wiring stopped.
