Hi, I'm about to do a re-dye on my 1997 boxster, I was wondering if there would be enough interest from you guys for me to take lots of pictures and do a write up as to how I am doing this.
Franco
Are you going to use Color Plus Surflex leather dyes or something else? I've used their black to match where my seats were slightly scuffed and their color was a perfect match with the OEM color
Are you doing a color change or a true re-dye? What products are you going to use. Good luck and much success. Please post pictures.
I will be removing the old shiny cardboard textured dye using lacquer thinner and the re-dye will be done with Leatherique Products.
I could have changed the color but decided to stay with the original, sent them a sample I cut out which they used to replicate the exact same color.
