This can't be a good sign. When I turn the car on, it will now frequently say "System error: Amplifier, Navigation System not available."
If I kill the ignition and start it up again, it seems to work the second time (although this behaviour just started this morning). Unfortunately, the car is no longer under warranty.
Any idea if this is a simple software fix at the dealer or is the Amp/Nav hardware failing?
Let the PCM check, if you have done an update by yourself that could be the problem.
Have you added any componets to the MOST system or retro fitted the PCM ? The MOST loop has a set sequence for devices, have you added a new device recently ?
