Hello guys. With Porsches being so low to the ground, will it be possible to use a set of ramps, such as the Rhino 12,000:
Thanks in advance,
Alex
They work fine with my '01 Boxster (slightly lowered with ROW 030 suspension). I've heard others have had success with them as well. They are not overly wide for the rear tires, so you need to have your tires straight on the ramp
I bought mine at AutoZone, then saw them a bit cheaper at WalMart - try there first
Edited by geoff
