I have either a 2+ or a 3. I forget which one I ended up getting. Make sure you let them know if you have a lightweight single mass flywheel. Otherwise, you'll find yourself stalling out for a while until you get really used to it.
So far I've been very happy with it. By this time I would have burned up the Sachs Sport clutch. The people at Spec were very helpful in getting the right one to fit my car.
-Michael
I have a Spec stage 2 and it's worked fine. I'd agree that it's a strange feeling to go from completly worn out to stage two. If you need to replace it might as well upgrade. :D
Is their a website for the Porsche Spec clutch/flywheel upgrades? Or does anyone else have suggestions on who to go through other than Spec or FVD? Any recommendations?
