This was my first season doing DE's. I have a 2000 Boxster S with the 18" sport wheels, running with PS2's. It's my daily driver but I store it in winter. I've been thinking of getting another set of wheels and put Sport Cups on them for next season (I still want to drive it to the track). Is there value in running stock 17 inch wheels versus 18?
Thanks, Jim
Assuming you keep the width the same? If the 17" wheels are narrower, then the answer is obvious: contact patch.
17" pro: Much cheaper tires and you'll be going through lots of those if you do track events regularly.
cons: Slightly slower reaction time since the car will be slightly more 'springy' with the same suspension. You may have a problem in the future if you ever want to upgrade your brake calipers.
Some people may propose weight factor, but I've done quick calculations between 17" and 18" forged wheels with either michelin PSC or yokohama AD07. I have the found the combined weights of both setups are nearly identical.
Many of the hot-shoe-fast-guys in Boxster class use 17X8.5 wheels with 245/40/17 track tires for low weight/max grip, widest choice of track tires, and the ability to rotate tires around for even wear. Good cost/benefit in a dedicated set of track tires. Maybe not a great novice setup as the tail will rotate more freely here.
Edited by Topless
