I dont know if this has been asked before but everytime I fill up (gas) and turn my Pcar on the oil warning level light turns on. I read on the manual that if the light turned on you must turn off car. So I just turn the car off and on and the light does not come on. The oil levels are good and only happens everytime I fill up. Is this normal?
Low oil pressure(red warning light) and the automatic oil level(amber scale that counts down) are two different things. Don't operate the engine if the red warning comes on with the engine running. It's normal for a bulb check when the key is turned on for oil pressure and the oil level will operate every time the ignition is turned on. Have a closer read through the manual would be my first step.
