I have a '04 CS and twice now after running the A/C for several hours on a long drive, the air starts to warm up to the point that that even with it turned all the way to the lowest temperature, the air still stays warm. After parking for several hours, there was a HUGE puddle of water from what I assume is the A/C condenser. It happened a second time, but didn't appear to drain this time. Does anyone know where the actual drain is (pictures maybe?) and what needs to be done to clear the line?
Thanks in advance.
I would say by your description that the evaorator is actualling "freezing up". Since there was a puddle underneath, I would say that the drain is clear.
Their are several causes of evaporator freezing, the most common of which is a slightly low refridgerant charge,caused by a leak in system. There can also be issues with other components in the a/c system that may take longer to diagnois. I would recomend that you find a reliable shop to do an evac and recharge with dye(in case system goes down again can check for leaks easier). Svansyoc
