Don't really know where to start on this issue, 01 boxster s, the passenger seat heater works fine, but the driver seat does not. The fuse is ok since the passenger seat works, checked it just for fun any how. But when I press the button for the driver seat the light blinks twice red and wont stay on. Where hould i begin what is normal resistance for the heater coil once get to that point?
Also im told do not remove the driver seat with out disconnecting the battery first as it will throw a code that cannot be removed, is this true?
ltaudio:
Try this link too:
http://www.renntech.org/forums/index.php?s...ic=22767&hl
Regards, Maurice.
No go swapped switches and relays no solution there, any idea on the pinout for the relay plug. Like to meter the coil out without removing the seat.
