I own a 2001 996 TT, and am looking to buy new tires. The stock tires are only available in high performance summer tires. I am more likely to drive in the rain and snow than go 150 mph. I was looking at going 225/40-18 in the front and 265/35-18 in the back. I think I will have to buy new wheels because a 265 will not fit on an 11" wheel. Has anyone tried this combination or have any input. I would like to find a solution to buying new rear tires every 8,000 miles.
thanks,
Joel
thanks,
Joel
Well, AFAIK the Turbo comes with 295/30-18 in the rear - thus 11" wheels work well. As to tyres, I'd recommend the Yoko Advan Sport if you need a tyre that will not mind rain and cold while still performing very well - and very predictably - in the dry. As to the solution to buying new rear tyres every 8000 miles, check rear toe-in and drive more conservatively. Unfortunately there is no real silver bullet, but I was able to make the Yokos last ~25k kms, 15kmi or so, on European roads.
nmiss is right....there's no real remedy for getting much more mileage out of your rear tires. As long as you have them properly aligned and balanced....they usually wear out at a two to one ratio....two sets of rears to one set of fronts....that is if you're primarily a street driver with some spirited driving in the mountains or twisties. I run 315 Michelins in the back and drive conservatively...still only get about 8-9000 miles out of a set of tires.....and the Michelin's run about $450 each!! The fronts look almost new. I stayed in the 18 inch wheel since I prefer a bit more tire on there to absorb the roadway....
This is a price you pay for driving a Porsche...and it's worse if you drive on 19's since they have less rubber...and are more prone to denting a wheel in a pothole.
