Hi - This might sound like a silly question, but.... I want to end up with the car about 2 foot in the air with all wheels off the ground. I have jack stands and a trolley jack etc, but I don't know where else I can jack the car up (other than the four points - behind the front wheels / infront of the rear wheels) and it is these points where the jack stands should go (I believe).
Any help would be greatly appreciated....
Derek
Beware of jacking under the engine. That puts the load on the motor mounts which can make them leak. I had been jacking by this method then noticed an oily, coffee colored liquid dripping out-motor mounts.
