Unfortunatley, Prestone II is not going to cut it here.
Heck, one even needs a brand specific oil in the Porsche. The engineers at Porsche would never let us off
that easy. ;)
If you flush the coolant system you can use non Porsche coolant but there are only a few others that work well. If you mix coolant, it can turn into a gelatin and kill your engine. Which makes me feel like a $30 gallon of Porsche coolant isn't to expensive. (Since it's 50/50 with distilled water, your sort of getting two gallons).
What can I use for coolant? I don't mind using the Porsche product it's just the dealer is 30 minutes away. The Walmart is 5.
I call that a good excuse for a Boxstercize!
