Hi Loren,
I'm in the process of adding a RS pulley because the previous owner did not do so when installing the RS clutch & flywheel. I just wanted to know if you can confirm that the pulley bolt PN is: 993-102-550-80. Also, I was told that the RS pulley has a different TQ spec than the standard GT3 part?
Thank you!
