Hi - 2001 TT - the above warning comes up on the screen - is this likely to a failed fan motor or a wiring fault or something else?
Derek
I would start by checking the wiring on the rear lid fan.
If it is not something obvious there then you likely need to run a couple of tests with a PST2 or PIWIS to be sure.
