I replaced the cluster in my 04 boxster yesterday and my radio now says protected, it wont turn on or do jack. I have ALL the manuals that came with the car, And on the matenence maual i think it has the radio codes, can you please tell me what number they would start with and whats the process in order to get the radio working again.!!!
thanks, however mnaybe i'm an idiot, but what do you do with those numbers? Once you turn on the radio and see the work protected, what do you do NEXT?
CDR-23 do not have security codes.
If the CDR-23 is changed (or sometimes if something else is changed on the MOST bus)) it has to be reset using a PST2 or PIWIS tester.
