I recently discovered that neither of my 3rd brake lights are coming on. This is a new problem and I have never noticed before. Any common issues/troubleshooting with these? Also, what fuse are they on (not on same one as other brake lights as I checked)? Both brake lights work along with all other lighting on the car. Is it possible that both lighting grids went out simultaneously? Possibly brake light switch at pedal? Thank you for your help.
I have a 1999 Carerra C2, 81k, completely factory.
I did do a couple of searches but to no avail so if someone knows of a previous post and can point me to the right direction that would be much appreciated.
Edited by peckel
