Good evening members,
I have searched but have failed to find much about 'steam cleaning' the 996 engine bay. Mine is not too dirty but I would like to have it look pristine. I found some info on 6peedonline.com. Is it safe to put a hose to the engine? :unsure: The post talks about covering the distributor and the alternator, I am not quite sure where they are on my car...
As far as products they recommend P21S Wheel Cleaner or Zymol Wheel Cleaner.
I'm not sure I want to do-it-myself, should this job be left to a professional?
Any info about your engine cleaning experiences will be greatly appreciated.
Alex
Edited by londoner06
Steam cleaning is not recommended, with water is possible if you use compressed air after cleaning to dry out the electric connectors. There is no distributor present on a 996 engine.
Thanks for the reply RFM. The last Porsche I had before the 996 was a 1990 C2 and did have the engine cleaned professionally. It looked brand-new again.
So far I've only cleaned the area I can reach by hand which is not to much since the 996 engine has such as small opening.
Alex
Any of the "cleaner/detailers" out there will work. Gunk makes one and Mcquires does also. I cleaned my Boxster and the water to rinse caused no problems. All that was required was to run the engine a bit after to dry it. Once you get it done, you can get at the places that are accessable. Good luck
