:welcome:
Go to your dealer and ask them to perform TSB W501 - Rear Window Adjustment (Quality Improvement Workshop Campaign).
You might want to have them check and see if other Workshop Campaigns have also been performed.
:welcome:
Pardon me , please tell me what is "Quality Improvement Workshop Campaign" , my is a cpo used car ,is it still under warranty?
thanks again
:welcome:
thanks again
The "Quality Improvement Workshop Campaign" was a series of fixes that were applied to early Cayenne's. Dealers were supposed to apply these updates/fixes at the next service.
Depending on your VIN and your car's options there could be up to 40 Workshop Campaign fixes that should have been applied.
If you have a CPO then they should have done these before they delivered the car to you. If they did not then they owe them to you.
:welcome:
thanks again
I talked to the dealer, they said for the rear windows, the Quality Improvement Workshop Campaign only apply to 03 but not 04.
any suggestion? can I fix it myself?
thanks
That was not true, all us 04 people had it done, although there was a difficult line to draw since a lot of 04's were renamed 03's anyway (you can tell by VIN lookup)
:welcome:
thanks again
thanks
:welcome:
thanks again
thanks
Hi, this problem normally occurs by water entering the rear wiper cover and ultimately through a poorly sealed microswitch housing. There was a campaign and then a campaign to replace that one. If you dont use the glass that often then do the following: open the glass, remove the plastic cover around the glass side locking pin. there is a smal electrical connection in there. Unplug the connection, refit the cover and close the glass. It wont open again unless you use the remote control on the key. If you want to fix it properly, go to the dealer and purchase the latest part number microswitch. usually the part number changes when the part has been improved. from latter 05 onwards this issue was resolved. Let me know how you get on.
Thanks for the instruction, I disconnected the plug, but it still show the warning sign on the dash, after went over a bump. Any ideas ?
thanks again
thanks again
Hi, did you insulate the plug? Does the glass open when the light comes on?
thanks again
No, I just unpluged them and yes, the light came on.
thanks again
Any input please ?
thanks
thanks again
Any input please ?
thanks
A good dealer would check it for you anyway. Sounds like you have a lazy dealer...
From the TSB:
"The affected Vehicle Identification Numbers are contained in the following VIN Ranges:
Model Year 2003 & 2004, US and Canadian Vehicles
WP1AB29P53LA60240 to WP1AB29P03LA60890 (M.Y. 2003) Cayenne S
WP1AB29P44LA60005 to WP1AB29P54LA71031 (M.Y. 2004) Cayenne S
WP1AC29P54LA90028 to WP1AC29P44LA92126 (M.Y. 2004) Cayenne Turbo"
thanks again
Any input please ?
thanks
From the TSB:
No, My vin is not in the range.
I don't understand why it still got triggered even though the switch is disconnected.
thanks again
Any input please ?
thanks
From the TSB:
I changed the switch and it is still like that !
any advise ?
thanks
thanks again
Any input please ?
thanks
From the TSB:
any advise ?
thanks
If the window is still popping open after you have changed the switch, it sounds like there is a short on the wiring loom that the switch connects to.
The wiring insulation could be chaffed, and must be contacting the chassis providing an electrical ground everytime you hit a bump, or if the mechanism is looking for power from the switch, you could have 2 wires in the loom shorting to one another everytime you do the 'bump' thing.
Inspection of the wiring loom will be required to confirm integrity.
Edited by bigbuzuki
