Yes but you will need to remove the painted lip first. Push the centres out of the plastic rivets and then remove the rivets you will then be able to remove the painted section. It should be obvious how to remove the black plastic bit from there.
Might be worth ensuring you have a few additional plastic rivets from your OPC, I'm not sure how easy it will be to retrieve the centres once they are pushed out.
Can the Black sections be removed, which are visible when the spoiler is up? If so, how?
