Loren, I have a 99 c2 SP Carrera. the temperature gauge needle is constant in the middle of the '0' in 180. I'm in Southern CA. Both front fans run when warmed up, but I have not witnessed the engine compartment fan running.
When exactly does it turn on? Obviously, there must be a certain temp that activates it. Do you know what that would be?
http://www.renntech.org/forums/index.php?s...ost&p=72289
Thank you Loren!
