Boxster owners don't do this! During a drive last weekend I put a couple of sweaters on the back deck area (with the top up). Later, while at a stop light I decided to lower the top. I forgot about the sweaters back there. Just as the top was closing I heard a snap sound. The socket portion broke off from the actuating arm on each side. The local dealer says I have to buy the entire arm with socket at $60 per side. But the white plastic socket portion is threaded onto the end of the arm. It sure looks like it is meant to be adjusted. I'm glad the Porsche engineers designed a component to break before bending something. But it seems strange that I can't just get the broken plastic part. Is there a part number for this piece? The Illustration number is 811-12 part number 4. I need the fitting shown on the left end of arm #4.
Contadino
Contadino
Contadino:
It's true that Porsche only sells the complete push rod assemblies. There is, however, another independent source for just the white plastic cups.
I have just sent you a PM with the info you need.
Regards, Maurice.
Contadino
Contadino:
Regards, Maurice.
Maurice,
Would you also send me the "independent source " for this part.
Thank you.
Sean
Maurice,
Thank you.
Sean
PM Sent.
Regards, Maurice.
  • 2 months later...
Maurice,
Thank you.
Sean
PM Sent.
Regards, Maurice.
Maurice,
Could you also send me this information? I would like to get the plastic parts. I was not able to find it on ebay anymore from previous threads.
Mike
  • 4 weeks later...
Hi Maurice,
I have the same issue with the white plastic cups. Would you be able to send me the same link? Thanks!
Chuck
Hi Maurice,
I would like to get the plastic parts but was not able to find it on ebay anymore or from any previous threads.
Thanks for your assistance!
Michaelwalker123
Michael
Happy to be able to oblige!
P.M. SENT!
Let me know if you need any assistance before or after the parts arrive ...these tops are terrific, but can be a royal PITA if one is not attuned to its weak points///\\\
Regards,, Maurice.
Hi Maurice,
Michaelwalker123
Michael
P.M. SENT!
Regards,, Maurice.
Sorry Maurice but I was not able to find a PM from you-not is SPAM folder. Could you resend please?
Thanks again,
MW123
PM means Personal Message sent here on the forum.
If you have a PM it will show up as a number near your login name at the top right. Or you can just use the dropdown menu near your name to go to your messages.
Hi Maurice,
Michaelwalker123
Michael
P.M. SENT!
Regards,, Maurice.
Thanks again,
MW123
Regards, Maurice.
  • 12 years later...
