I've noticed a pretty distinct sulfur smell when I open up the front boot of the car ('04 996 C4S).
I'm not really sure what is causing the smell. Is it the battery?
Thanks in advance for any ideas.
CMiYC,
Most likely the battery as it uses sulphuric acid ( and water) as the elctrolyte. I would check to see if the battery is low on water ( use distilled to top off). Is this the original battery?? If so, it may be getting close to replace.
Demosan :cheers:
In looking over the service records, I think this is the original battery. So it is starting its 5th year of life.
I'm not sure why it didn't occur to me sooner, but at least I think I know what is causing the smell...
Thanks guys.
