Hi Guys, I have an X50 with factory X73 suspension and would like to know whether or not anyone knows how x73 differs from the stock suspension on the 996GT2. I understand that the GT2 is 20mm lower than the stock turbo (RoW suspension) which is the same as x73, hence I wonder whether they are the same.
I don't believe x73 is adjustable tho, whereas the GT2 is I think.
Can anyone confirm ?
Cheers.
Thanks Loren - are the GT2 coilovers adjustable for compression and rebound ?
Presumably then the x73 set up is similar to the GT2's stock setting with the advantage that the GT2 can be adjusted depending on use from therein, thus if a GT2 owner wants a more compliant ride he can adjust accordingly ?
