Does anyone know the torque specs for the caliper mounting bolts on the 987? I found this article: Replacing Rotor on 996 GT3 which says the they should be torqued to 63 ft-lbs. Is it the same on the Cayman S?
Thanks in advance!
Edited by KS-CS
what about the torque for the caliper itself on
a 2002 996 I'm rebuilding my calipers. Thanks in advance!
ralegen:
Do you have a source for caliper rebuild kits?
Regards, Maurice.
  • 11 months later...
Yes, 63 ftlb.
Loren, I thought it was 96 foot pounds? Just like on all 996's and 997's that s what is says in the tech manual.
Yes, 63 ftlb.
Caliper torque - not wheel bolt torque.
  • 8 years later...
