I have a PST2 (on KTS500 basis) running V24. Everything works fine except the resistance measurement with the URI module. Once I activate resistance I get a Windows error message saying something about LABEL_63 and negative resistance. I bought another URI box and swapped the board into the PST2 because I suspected a hardware defect. However, the results are the same.
I know that there are two hardware versions of the URI PCB out there. Apparently most of the PST2 had the earlier revision while the KTS500 at some point where switched over to the newer version. Does anyone have any insight into this?
Cheers,
Ingo
