I have seen the multi piece kits but I was sure you could buy just the one 19mm protective socket, but so far Google has failed me...
The socket I saw had the leading edge rounded and covered in plastic.
Any hints?
Yes, electrical tape will work, but I was hoping to have the leading edge of the socket covered as well, much like the Stahlwille socket in the pdf.
In fact the sets I found at Jack's tools looked almost identical to the German made unit.
http://www.jackstoolshed.com/product/02410...Molybdenum.html
The one I remember seeing looked like the front edge was molded HDPE. The impact socket I have been using seem a bit loose and I don't want to damage the newly installed stainless steel lug bolts by rounding the edges with a poor fitting socket.
