I just orderd my GT3 seats, currently I have heated power seats.
I also ordered both side seat belt recepticles so that I don't have to mess with my orig seats to make sure it's easy to put the old ones back in.
Is there anything else... Some of the DIY show that there is a connector that needs to be removed from the seat. Is that correct? Can you order just the connector so that I don't have to dissasemble old seats.
Thanks...
Corey
Keep the key OUT of the ignition unless you want an airbag light.
Well I think I need to have key in the ignition to remove the bolts, I just won't unplug the seats till I take the key out.
But the big question is the connector... Does anything need to be removed from the seat if I have new seat recepticles or is there a connector on the floor that the recepticle can just plug into.
