Not exactly sure how to explain it, but there is what seems to be a "filmy" residue on my windhield that I cannot get rid of. It literally blinds you as the sun hits it. So far I have tried Windex, Windex with vinegar, changed out the wipers, and I even took a razor blade to the glass trying to "scrape" the residue off. No dice. Anyone have any tips? The car is stored indoors at all times and this problem has been ongoing for quite some time now.
I had that problem on my 914. I used "Grease Lightning" with a paper towel, let it dry for a few minutes, then use "invisible glass" with a microfiber towel for the final clean. I had to use the invisible glass two times.
I purchased all the products at home depot. I was very happy with the results. If this doesn't work, repeat the process a few times.
Try newspaper. Take two sheets, crumple them up, wet one and scrub the window. Dry with the other. Finish with Invisible Glass - great stuff.
Jim
