I am looking for winter tires and found a guy selling his Boxster wheels OEM 16 inches.
He is also selling 17 inch aftermarket (which he used also on his Boxster).
I got them checked by one of workshops. But as they are used to "rich" customers - dealing with people with Ferraris, Lambos and Porsche collectors - they told me one of these is rubbing against the strut and the other is touching the brake (did not tell me which is which).
They advised to buy new rims and wheels!! Which I thought is not so money efficient way...
However, I have seen people posted the use of spacers. And also, using different wheels. I was thinking of reserving the low profiles for summer and a bit thicker ones for winter as I would be driving on snow and occasional ice.
In your opinion, what should i do?
(Currently, I have stock 18 inch wheels...)
thanx'
If I remember correctly the 996 rotors are the same as the 986 Boxster S. The base Boxster has smaler rotors than a Boxster S. It has been said you cannot put 16" wheels from the base Boxster on a Boxster S because the wheels will not clear the rotors. Therefore 16" wheels will not clear your 996 rotors.
Tool Pants is correct. On the Porsche TSB Winter Tire, Wheel, & Snow Chain Applications it states on all the 16 inch wheels "not for Boxster S".
Boxster S and Carrera use the same rotors (except C4S).
