Hi everyone,
The 1992 C2 Cabriolet with Tiptronic Trans is the first Porsche I have owned with an automatic trans. Bought the car for my wife to make it easier for her to drive in stop-and-go traffic.
Quick question: Are the "Gear Indictaor/Position" lights (red arrow) on the dash supposed to be lit up even if the headlights/parking lights are not turned on???FYI: I sometimes have to turn on the headlights so the red arrow lights up to show which gear (1,2,3,4) I am in when in Tip mode. Is this normal??? In auto mode I realize the Gear Indicator on the console area clearly shows what gear you are in.
Hope someone with a Tiptronic Trans can help me out.
Mahalo, 808C4
Hi everyone,
Mahalo, 808C4
Replace the Interior Light 7.5A fuse. This was what fixed mine (not to mention fixing the dome light).
Thanks very much guys!!! :) :clapping: Finally someone replies to help me....this forum is the bomb!
FYI: Fo rthose that care, I am making headway to fix my wifes C2 Cab with Tiptronic. Isolated the shift mode problem to the Reverse Light circuit. If I start the car in "N" the Tip system works properly. Now I need to figure out how to correct the Reverse Light circuit/wiring so I can start the car normally and so the Tip system will work properly. Will keep everyone informed. If anyone has any advice it will be greatly appreciated!!!
Mahalo, 808C4
Mahalo, 808C4
Okay now I'm pretty disappointed! I changed the 7.5 fuse and it immeditley blows...what could be wrong? Guys I need your help on this one! I checked the door pin switches and they both look fine, I checked the interior light fixture and it doesn't appear to have a short. FYI Tried the light fixture in all three positions and the darn fuse contiues to blow. What else could it be or where is the most common place to check??? Your expertise is much welcomed - please advise soon!
Best, 808C4
The selector light is on the same circut as the interior light. Is the wireing shorting on the light side?? Pull the socket out between the visors. Mine was broken back there.
Thanks Tom for the suggestion/tip. I did pull the light fixture out and it lloked to be intact. The bulb even looked fine... Do I need to pull the gauge out and chek the wire behind it? I also pulled the fuse box to check the underside of the fuse...the wires looked ok. There must be a fault somewhere along the line because the when I place a new fuse in th efuse box...it immediately blows. Would yu happen to have a wiring diagram for this?
Appreciate you taking time to help me!!!
Aloha,
JS (aka 808C4)
Hello all,
I am happy to report...after a couple of years I finally figured out the problem! Turned out to be the bonnet light fixture grounding against the inside of the hood. After pulling the light fixture out to change the bulb...I discovered when replacing it into the hood holder that the fixture seemed to be very close and making direct contact with the metal. So I pulled it out again...put another 7.5 amp fuse in the fuse box, it didn't immediately blow this time...an haloyula the interior light came on, the dash gear indicator selector light came on and the glove box light worked!!!
All's good now!!! Now to fix the reverse lights on in Park problem...will keep you posted.
Aloha,
  • 6 years later...
"Yep.. that fixd mine also.. Fuse #11 in the fuse box."
I know this is an old post however +1 on the fuse for a 968.  Fuse #11 was 15A.
--clawless
1994 968 tip
2008 Cayenne
