Hello,
I am installing a set of Recaro Profi seats using 996 manual seat rails and Brey-Krause brackets. The BK brackets use the same bolts on the top on the 996 seat rail that attach stock seat to the rail.
Does anyone happen to know the torque values for these bolts: it is two 13mm nuts on front and two T-40 bolts on the back?
I have tried searching every way possible and can not turn up an answer.
Matt
48 ftlb.
Loren,
As always, thank you! That was the last piece of the puzzle of getting the seats installed. I'll post some pictures after the weekend.
Matt
