I have recently taken my US Cayenne Turbo 2004 to Europe. The navigation system worked fine in the US but it does not seem to work with the CDs for Europe.
Do I need to reset the PCM pressing 148 all at once? Does anyone know how to make it work?
Roman
The PCM have to be reprogrammed with a PIWIS tester to Europe specs in a dealership.
Unfortunately you will need to change the unit. When I had a 2004 Cayenne S, I installed a NAV unit purchased on eBay, it was a European unit. I couldn’t get it to work so I sent it to Becker for repair. It was then I was informed it was a European unit and will not work in the US, I ended up trading it in with them to purchase a US configured model. I would assume you are having the same problem.
Looks strange to me, GPS use US army satellites as info also in Europe. I have got a couple of weeks ago some rebuild PCM units, all with US VIN numbers still programmed, here to build in European cars without problems after reprogramming.
