Hi all,
I'm about to put on a set of 19" OEM lobster claw 997 wheels on my 996 and I was told that I may need spacers for the front. Not so much for them to fit on, but also just for looks sake as it will not see so recessed into the wheel wells.
Can someone confirm this and if so what size spacers are used?
Cheers
Aaron
Depending on the front offsets and widths, which are printed on the wheel near the valve stem, you may want a 7mm or 15mm spacer. Some makes are 14 or 16mm, pretty much the same difference. If you do buy 15mm spacers, make sure they are hubcentric (they will have a raised ring around the center)
