HI, something wrong with my C2's gears... Its as if the shifter cables are not connected, Its loose and won't get into gear. So I removed the center console to look
if the shifter cables were connected, and they are. So where could the problem be?
thanks
The cables connect on the right top side of the transmission. You can easily see them from underneath and will know if one of them is wrong.
Rick
99 996C4
87 944S
