I just bought a used PCM 2.1 and Navigation for my car. The PCM install within 5 mins and everything is working correctly. However, I'm having trouble with the navigation unit. I believe the 997 S and GT3 (mine) uses the vertical mount navigation and my part numbers below should be for this. I cannot find a space to fit the unit! Am I suppose to remove the plastic cover in the center of the trunk to place the DVD drive?
Navigation drive 997.642.159.01
Bracke 997.642.231.00
Some help would be great! Thanks!
997C4 and apparently your GT3 use a vertical mount in front of the bulkhead. The 997C2 & S use horizontal mount where you have the black hump.
thanks! but where is the bulkhead? am i missing other mounting materials?
If you contribute to Renntech you can get access to the Technical Bulleting that tells you how to mount the navigation system on the bukhead, and it also lists the parts you need to mount it
John
Here is a link showing the part numbers and diagram for your vehicle:
http://www.autoatlanta.com/model/GT32-07-08/911-00.htm
It looks similar to the listing for the standard 997 (carrera 4/4S) which is slightly different than the non 4/4S. the vertical mount is shown as item #3 but it does show the horizontal mount as well. on my 06 997 S, I have a drawer location in front of the battery where this unit is supposed to go.
Do you mind me asking how much you paid and if you plan on selling the horizontal unit for a vertical one, I would be interested. I've seen them on Ebay naturally (right now, most are vertical mounts). Somewhere I've also read that the horizontal DVD when placed in the vertical position has issues and seems to be unstable for GPS. Did you have to replace the PCM unit (or did it just come paired with the DVD unit)?
Thank you! It looks like i have the correct dvd drive and mounts but need a few more hardware to mount the nav drive.
I do not have a horizontal unit for sale. i purchased the dvd drive knowing i needed a vertical mount one. I also bought the pcm paired with the dvd unit.
  • 4 weeks later...
Just be a little careful with matching parts. There are different part numbers listed for the PCM units depending if the car has a Bose system and if the DVD drive is vertically or horizontally mounted. The part number for a PCM for a Gt3 / Turbo and Carrera 4 is different to that of a 911 boxster or cayman. If you trawl through hte TSB section and the online parts catalogue you should be able to ascertain the appropriate parts. It is also important that the DVD drive matches the PCM in terms of firmware/ software level.
