In order to have the Prodigy controller to work correctly on my Cayenne S 2004, I had to connect one wire directly to the brake switch located just above the brake pedal. I am now moving this controller to my Cayenne TT 2008, but the brake switch is not located there anymore. Any idea where I could tap the Prodigy brake signal?
The brake switch is located on the ABS hydraulic group, under the DME right front side of the car, in the room under the plastic trim ( wiper area )
