How to install iPorsche - Porsche iPod integration system
Sorry, folks this author has removed the external source for the images in this DIY Tutorial. I will leave the text here as it may help some people. ------------------------------------------------------------------------ Things you'll need: 1 iPorsche kit 1 T20 Torx Screwdriver ~30 minutes of your time Also, make sure you know your radio code. First, take the radio removal keys and insert them into the slots on your head unit until you hear a click. The keys are labeled L and R. Onc
Edited by SNaray8442
  • 3 months later...
Hi I have a 03 C2 with a cdr23, will this work on my system? Where did yo purchase this and what was the cost?
No, CDR 23 is a MOST (fiber optic) connected radio.
Do a search here for iPod and CDR-23 you will see what others have done (i.e. in Search put +iPod +CDR-23 +CDR23).
So how does this work? You instrucitons show how to get the lower center console out but how does it hook up to the radio, and how is the radio programmed?
Not to steal the original poster's thunder, but take a look over in the 986 DIY Accessories section for a write-up regarding modifying a Blaupunkt auxiliary port cable to work with the CDR-220 stereo systems. The original poster here has a detailed step by step for routing the cable which my instructions lack. I'm curious to see what this "iPorsche" is exactly.
Cheers,
-J
Edited by RaisedOnPorsches
I pulled my radio out and the optical in/out cable for the speakers are not being used the speaker cables are pluged in just like on a cdr220? Does this mean I have a regular system? I have tred to search if anyone else has this?
  • 5 years later...
2000 c2 with original single CD radio. Can it be modified to accommodate an iphone so I can play music via an app from my phone through the radio speakers? Thanks.
