Just took delivery on 2009 GTS with factory installed hitch. No sweat installing Ball. Problem is electric; if I remove the square plastic cover held by 4 screws the whole connector assembly comes loose. What am I doing wrong?
Thank you
Richard
you need to buy a US adapter from Pepboys or uhaul.
Thank you
Richard
dont forget you will need a brake controller, electronic
Ordered on from UHaul. How does it install?
