I have an '01 Boxster S with 102,000 miles on it. I had a check engine light come on yesterday, with the following codes;
DTC Count = 5
Fault Number:P1130
Description:Porsche fault code 361 - Oxygen sensing adaptation
Repair Infomation:idle range bank 2
DTC Count = 5
Fault Number:P0300
Description:Porsche fault code 62 - Misfire damaging to cat.
Repair Infomation:converter
DTC Count = 5
Fault Number:P0306
Description:Porsche fault code 68 - Cylinder 6 misfire damaging to
Repair Infomation:cat. converter
DTC Count = 5
Fault Number:P0305
Description:Porsche fault code 67 - Cylinder 5 misfire damaging to
DTC Count = 5
Fault Number:P1128
Description:Porsche fault code 360 - Oxygen sensing adaptation
Repair Infomation:idle range bank 1
I reset the CEL (I have a Durametric)
Today, While driving (Right after changing the oil) the Check Engine light flickered, and the engine felt like it was stuttering a bit. The codes are;
Fault Number:P1130
DTC Count = 5
Fault Number:P0300
DTC Count = 5
Fault Number:P0306
DTC Count = 5
Fault Number:P0305
DTC Count = 5
Fault Number:P1128
Does this indicate any issues that changing all 4 O2 sensors wont solve?
I should start with a coil check on cyl. 5 and 6 ( cyl. 5 is located middle left side - cyl. 6 most rear one on the left side ), if they are cracked renew all the coils. Clear the codes and try again.
Thanks, I will do that today.
