It is a bit work... might I ask why you need to remove it?
i was afraid of that. removing to see if i can find my rattle in my dash! :angry: it's sounds quite annoying
Since the car is likely under warranty let the dealer/OPC fix it.
i've tried 2 dealers already and no luck. the sound only appears on certain road conditions. oddly, on bumpy roads, it does not always happen. but the sound occurs around where i live and the freeway on travel on most. and with just my luck, the sound was hard to duplicate around the roads near the dealers!
Easy as pie!!!
http://www.flickr.com/photos/33889996@N00/...57600783213574/
This thread also shows Dension bluetooth install.
PM me with questions.
it doesn't look half that bad! Thanks!
Watch it when you remove the panel with the 12 volt outlet, it's easy to short it out and blow the fuse if you are not careful!! No biggie if you do!
thanks for the heads up! removed the glovebox without a problem! not too bad...
now i have a possible lead, need to test drive tomorrow, hopeuflly it's it!
