My brother accidently put 87 octane gas in my 97 boxster......check engine light came on later that day. Can low octane fuel make the check engine light come on?
I have used low octane over the 5 years I have owned my 1997 with no problems. The emission system on a 1997 is different and you can drive without the cap and no light. It is 1998 up that the cap is an issue.
Just keep driving the car and the light will go out if whatever fault set it off is not detected again. Or use a code reader to figure out the fault.
