any one with a relay chart for my 2002 996 (cabrio) ? . They are located just over the fuse box .
Maybe somebody can email me a picture . danieldanko@yahoo.com
thank you
ps.
here is a pic of my relay box , but it looks like one is missing plus my heated seats and my xenons lights are not working . I just want to make sure that all of the are in proper place.
Edited by zgdanska
All lights are on except xenon's. when I started to play with that I plug the relay from 21 to 22 and my xenon's kicked in(for a minute). But it thing is just a bad wire or something (maybe light switch). I have the wire diagram from 1999 to 2001 only so there is no info about the xenon's . Also will be great if you guys have the list of the circuit breakers so I can pint point the source . Again thanks for your help . Daniel :renntech:
MY02 is very different than MY99 to MY01.
Either way those two fan relays have nothing to do with your lights unless there is a short somewhere.
There are no circuit breakers - there are fuses. And, if a fuse was blown they would not come on for a few seconds.
If the fuses are good and you have a bunch of electrical anomalies then I suspect the ignition switch.
all fuses are ok . i just dont know witch one is for my xenons . if i can get the 12v to the right fuse then my xenons should turn on . and then is just the light switch ???? i guess
ps.
the relay that i am missing is the same one as the others "52" ???
Edited by zgdanska
Thanks Loren for your help. :cheers:
I just order a new switch from pelican parts ---113$ and 6$ for the relay .
ps.
My 911 is with auto trany, but is there a way so can change the way that my trany shifts . The way it works now it starts from 2nd gear and it goes very quickly to higher gears . It is good for mpg`s but not to sporty . I can use the tiptronic but i don't want to . Also I don't have the psm button . any ideas ? Looks like you know the stuff.
ps.
The MSRP for that switch is $111.67.
In the future you might want to try Sunset Imports (Porsche Parts at Dealer Cost) - they sell at cost plus 15%.
