i just purchased a cluster off ebay and was wondering if you swap the entire cluster do you loose your odometers orignal readings, or does the newly swapped cluster change to read the new cars actual odomter readings...I have been told that it will automaticlly change. If not i can swap the odomter portion on the clusters..THANKS FOR YOUR HELP!!!
2004 Boxster with Tip (non s)
This has been covered before. Who told you that?
The mileage is stored in the instrument cluster. So if you buy a used cluster with say 30,000 miles on it and you put it in a car with 15,000 miles, then the ebay cluster when connected to your car will display 30,000 miles.
If you search around there are companies who can change the mileage to match your car. You have to ship them the cluster.
